prayingmantis
- Mar 16, 2014
- 44
I haven't been able to get the boat up to 65 yet. When I bought the boat it swayed a lot. It would start to sway at 60 mph. It seemed to be ok at 60 but past that I'm not sure yet. I moved it up about a foot. I have seen posts that say the general rule is that the back of the boat should be at the back of the trailer.
Ayuh,.... I find 10% to 15% of the gross weight, on the tongue, stops any swayin',...
ditto on thisMove the winch stand up to the trailer jack. Move the boat all the way up and you might be good. You might have to move the jack forward to accomplish this. Looks like it's way to far back.Transom should be even with the end of the bunks. This should bring the transom straps straight down.Not straight back like in the pic.
The back of the boat is about 5-6" passed the bunks. I moved up a couple inches. It is at 120 lbs right now. I think it is still 40-50 lbs light. It also has a full tank of gas. I'm going to move it up so it is even with the bunks. After I do that if is too close to my truck is it safe to use a 12" extension on the hitch
I would not worry where the boats sits in relation to the bunks, get that boat adjusted to give you the needed tongue weight first and foremost. Once you have the proper tongue wt then you can lengthen tongue, move jack, make bunks longer or what ever else may be needed to support the boat hull but that tongue wt is the most critical. I needed a few more pounds on my trailer as well so I moved the spare tire forward to lay between the bow and the winch stand and now it is perfect.
