livysdaddy
- Jun 11, 2011
- 14
I am new to I/o boats but am fairly mechanically inclined. I have a '89 omc 210 horizon four winns with a cobra outdrive and 5.7 engine with a rodchester 4bbl carb. I have just redone the top half initally started out as just rebuilding carb but pulled intake to see more about the engine kinda suspected water in oil and was right so I went ahead n pulled heads and had them checked and reworked. Got it all back together last night n started it up. Started very easily ran well but had a miss kinda of at idle(1100 rpm) but once u throttled it up it smoothed out some what but if you really reved it up it would pop through carb a bit and u could hear a miss in the exahust. I changed plugs this morning(champion rv8-c) cap n rotor seemed to be fine. When I put it in gear u could hear a small bit of grinding as it went into gear in both foward and reverse. Is this caused by my idle being too high? What should my neutral idle speed be? As for the small miss and poping would the carb being a little out of adjustment cause this or would timing most likely be the problem? Thanks in advance for any suggestions! If I am going to have A boat I have got to be able to work on it myself!!!!
