Re: Does Outboard Fit Boat
(Rick posted jus as I did....His graphic will tell where cavitation plate is and general relationships of trasom and motor) <br />You said short shaft, lets make sure. There are two basic lengths of motor legs in your case. 15" and 20". Measure the from the center and top of your transom to the bottom of the transom. It should be 15" or 20" plus or minus an inch. Then on the motor, measure from the transom clamp in the normal position down, from the underside to the top of the cavitaton plate. This demension should be 16-18" for the 15" transom. The longer leg should be 21 to 22" for the 20" transom. Simply stated, if you put the long leg (20") motor on the 15" transom, the motor will stick WAY to far down into the water and actually slow you down quite a bit. If you put the short motor leg on the 20" transom, the prop will run out of the water and cavitate and you won't go anywhere. IF you have a mismatch get back and I have some solutions that will fix the problem in your case.<br /> Generaly, a good elevaton to mount the motor in your case is with the cavitation plate level and even with the bottom of the boat or 1" ABOVE the bottom of the transom. Do not go any higher at this time. Let us know what your transom height and leg length is..
