Albers
- Apr 8, 2012
- 12
I have a 1993 Wellcraft/Excel 26se cruiser with a VP 5.7 carbureted with SP-C drive with a 1.61 ratio. Loaded weight is 5,800 lbs. Current prop is a 15.5" x 17p Solas 3 blade prop.
My problem is that it takes FOREVER to plane - even using the trim tabs and sometimes even on the way back from Catalina when the current is actually pushing me it is common for the boat to fall off of plane and seems like a loss of power.
I used to have a 15.5" x 15p and that seemed to do good and I could tach out easily at 5,500 + rpm so I thought I'd switch to a 17p to try to get a little better mileage - I didn't have these problems with that prop.
What confuses me is that on the original specs it shows this boat at 38.3 mph @ 4,500 rpm and 25.6 mph @ 3,250 cruise. With either the 15p or the current 17p the fastest this thing can go is around 25 but speed isn't my main goal - I use this on Long Beach to Catalina runs (30 mi) and am just trying to improve the fuel economy. If nobody has any input I was thinking of just cruising there at 7-10 kts and just see what mileage I get that way vs. the current 2 mpg I'm getting now. Should I just be happy with the 2mpg? is that expected for this size boat/motor/single prop setup?
