ScottinAZ
Master Chief Petty Officer
- Jun 25, 2009
- 831
I am at the point of my rebuild where I need to remake a doghouse cover for the engine.
Originally the doghouse was just plywood, fiberglass and some sprayed in foam for noise abatement. Personally I feel this is inadequate and a fire hazard.
I am considering building a frame out of angle iron that I can screw the plywood (either fiberglassed or polyurethaned for water resistance) outer cover to, and then use some automotive style underhood insulation for the inner, rather than the sprayed in foam that is a known fire hazard.
What is the standard way that others here have redone their doghouses, and am I overthinking this?
