DOLE FLUID PRODUCTS
Status
Not open for further replies.
irishwind
I have a 78 basscat with a manuel trim pump<br />its a dole model sp500 but it has stopped working and I dont know how to repair this can any one help with this.<br />I removed the large cap and got sprayed with hydraulic fluid good thing for saftey glasses
irishwind
Re: DOLE FLUID PRODUCTS
ive found the guy who invented this little gem<br />after talking with the ol'timer ive fixed my problem with 35 cents thaat was unbeilevable<br />all marine shops didn't know nothing except how to sell me an electric one for 600 installed what arip if any one has a question i can answer all about the S-P500
bpurcell
I have a problem with my Dole Fluid trim and can only hope that 35 cents will fix it. The red fluid is leaking from the side of the pump opposite of the handle. The exact location is where the pin sticks out of the side and is held in place by a washer clip.
Do I have a seal or o-ring leak and if so, where is it located? Also, can the handle be remove from the unit to clean/replace the debris and seals inside?
August 9th, 2005, 04:02 PM
Ayuh,... Irishwind hasn't been here since that was posted 4 Years ago,...
I doubt he's gonna be much Help,...
Seems what you've got is a rarity,... Got some Pictures,..??
bpurcell
Here you go. Have you ever seen such an invention?
bpurcell
The unit is leaking on this side where the round pin is shown on the side.
D
DJ
Guest
I have seen them and actually installed one myself, years ago.
They are incredibly simple.
There is nothing "special" in them. Any hydraulic shop will have the seals and o rings you may need. They will have to match them up so disassembly is needed first.
bpurcell
Have you ever disassembled one? If so, can the handle pin be removed from the unit?
tashasdaddy
CMC and Dole built very similar items. CMC caught on. this was before the manufacturers, started installing TNT. that it to a Hydrolic shop. they can fit it, rather than you screwing it up. it is just based on a hydrolic jack.
Status
