Don’t be me - save your coils
JerEazy
More as a warning: I was doing the Joe Reeves method to check and set my full advance timing. (Felt like I was a little off at WOT.
I only had one spark plug tester. So I set that on the top plug wire and unplugged the bottom and hung it over the side of the cowling away from everything.
The timing was too far advanced by 1 degree - (read 16 and should read 15 - plus 4 puts at 19 for proper setting.) so I retarded it and re checked - now all set.
go to do a test run - wouldn’t idle and only firing on top cyl- opened up the power pack swapped 1 and 2 leads and swapped plug wires (so assumed good coil was now set to bottom). As I feared, now firing on bottom. No spark from coil 2. Got home and confirmed with my tester. New coil ordered.
TLDR: adhere to what you’ve read. don’t try to start or turn over the engine without your plug wires hooked up to something or your day might get ruined and you may be out $40 on a new coil.
Faztbullet
That coil was going bad and that's why it felt a little off at WOT, didn't fail cause not grounded..1 degree off cannot be felt except in a HP/high RPM application
JerEazy
It was feeling off at WOT for a few weeks. But I was going through everything and wanted to cross it off the list to be sure.
Test was more of a functional test than an electrical test. I put a spark plug tester on it and no spark. Swapped it with the top coil (swapped the orange wires in the power pack) and got spark. I ran it through a test on the multi meter and (I am NOT an electrical guy - so please don’t beat me up on the terminology here and I’m sure my test wasn’t by the book. M But the “resistance” was much higher (900ish on the reader) compared to the functioning coil (at 500ish). To be sure it wasn’t the wires I re cut and installed the wire and still no go.
the coil was brand new - had already replaced them. Doesn’t mean it wasn’t bad from the start, it was a Sierra brand coil.
Put it new coil on last night - and now getting spark. Test run in about an hour before the water eats get insane.
JerEazy
Perfect run - 5400ish WOT- nothing to brag about on top speed - guess I need to be on the lookout for a 70
