Limited-Time
- Mar 30, 2005
- 5,820
First off I have the manual, and followed the prescribed procedure....But I have a few questions. First after putting the ignition system into base timing mode the RPM was set to 1300. The timing was then advanced to 10 deg BTDC. This caused the RPM to increase, so I reset the RPM and reset the timing, did this until the timing was 10 deg at 1300 RPM. is that correct?<br /><br />Next issue Adjusted Idle mixture and set idle RPM as described. Manual specifies idle speed "in gear". (Now my dumb question)IN gear on the trailer or in gear on the water. My common/uncommon sense says in the water.<br /><br />After completing the process I observed the timing up to 2500 RPM and it never went past 10 deg. Is this correct, I did remove the grounded lead at the correct point in the procedure.
