imported_ranger_6
- Nov 29, 2003
- 17
I have an 86 johnson 65HP. I have been following the FAQ's outboard won't start. I have good spark, good compression on all 3 cylinders and for the last few days I have been tracing my fuel lines to check for leaks. I found one and fixed, I changed all of the connectors and switched gas tanks. the only thing I haven't changed is the primer bulb but I think that it's good. I squirted pre-mix into the carb and it still won't start however while doing this my motor was tilted in the up position and I noticed an excessive amount of fluid collecting in the front of the cowl or whatever it's called. I smelled it and it's gas. I couldn't see anything leaking so I had a buddy turn it over while I looked and I noticed something leaking . it's a metal tube that goes into the lower unit ( I'm assuming that's where it goes) I can't really explain it any better. anyway fuel leaks out of there so can anyone help me? thanks. -Mike
