Re: Don't want to break it! HELP!
As for the comments about the sledge hammer... it's what I was told by an "old pro" locally. I didn't do it, but might have if it didn't come off as easy as it did. I believe in using just enough ooomph to do the job, not any more, and not any less, so as NOT to damage anything. Aluminum flywheels are not flimsy, but not bulletproof either. How many of you with electric starters can see where the teeth have been ground, or bent, by normal use.
Anyway.
I was told not to tighten the puller until the flywheel comes off completely, but to get it fairly tight, and then whack it. I used a rubber mallet, and alternated sides in a similar pattern to how you'd tighten lug nuts on a car tire. N0T a sledge. Three taps and it came of nice and easy.
As for holding the flywheel steady when cranking on the puller, I used a screwdriver to hold the flywheel from turning, stuck between the starter bolts, carefully so as not to let it slip, or scratch/bend the flywheel. I guess it's all a matter of how you use your tools. I think a strap wrench would have probably done an even better/safer job, but I went with what I had available. As long as you're gentle, I don't see any problem using what you have. Perhaps yall can correct me if I did something wrong?
