Hello All, Nice to see that there is a active Doral forum here.
I have some questions regarding my Doral Monteciello 2004.
I just got it and started to make her ready for the summer.
I have some ideas i would like to share with your all as it progresses, but for now i really need your help with some things.
1, The previous owner have removed the macerate pump.
I did buy a new unit but when i try to connect it have have some problems finding the correct cables.
I did find a connector with 3 wires and it was written waste on it. But when i flip the switch on the controll panel with the macerator symbol on it, no 12 v is set to it.
Do someone know what cable is supposed to be to the macerate unit?
Maybe you can take a pic of the cable?
2, Cushions
I want to order the front cushions that is used for the front sunbed.
I also want the rear cushion that is needed when you lower the white table and covert the rear section to a big sunbed.
If anyone knows where to buy this, new or used then let me know.
3, Electric windlass
My boat dont have the electric front windlass for the anchor, there is a puch button named winsh but in the fron where the anchor is , there is no engine.
Can this be fitted relative easy ? What engine is used?
Any pictures would help in order to locate a new motor for this.
4, wiper engine
The wiper engine have been removed and now there is just some loose cables.
Can anyone take a pic of the stock engine so i can see if i can find a replacement?
Or if possible to buy online.
5, Fuel tank meter.
My fuel tank meter works a bit odd, if you turn on and off the igntion a few times its seems to be showing correct.
But i wonder where you can buy a new unit as replacement.
Thanks for you time.
2, Cushions
4, wiper engine
5, Fuel tank meter.
