Double-axle Acutator on Single Axle trailer
Hippo68
Had to replace the actuator (UFP A-60) on my trailer. Manufacturer of the trailer must have used the wrong actuator as I noted that the part I took out was the model designed for dual-axle trailers. My trailer is a single axle. What problems would/could this potentially cause? Asking because i've had intermittent issues with wheels heating up to the point I can burn my fingertips on them after a few miles of towing.
the wheels heating up are because you dont have your brakes adjusted correctly and your brakes are dragging
or your wheel cylinders are hanging up and your brakes are dragging
briangcc
^^^Agree on both counts. Had a hung caliper last year and cooked the bearing grease because of it.
So...my recommendation is to repack the bearings once you figure out the brake issue.
Hippo68
Hmmm. Interesting diagnoses. The issue did occur once or twice the past two years. Last fall had the dealer re-do the pads and flush the lines. Issue got worse (more frequent) this spring. Dealer replaced the bearings as they were indeed cooked...and problem persisted. They did also check the calipers (supposedly) and flushed all the fluid.
I pulled the actuator because I've read that the rod can occasionally get stuck. I had also noticed the lack of a 'Clunk' when pulling forward after a stop as the actuator goes back to the towing position. I was unable to pop it back into place with the screwdriver technique. So the fact that the actuator is the incorrect model for a single-axle trailer is a red herring, you think?
I'm not a mechanic by any stretch, but would a stuck caliper affect both wheels? Both get hot - or both do not get hot. It's not just the one wheel.
NYBo
I believe that many actuators can be used with single or dual axle setups.
Check the rubber flex hose. These can collapse internally and act as a check valve, not fully releasing pressure.
