Re: Double lip seals?
I have no experience with those seals. But there are 2 types of seals in general, dust seals, and oil seals. (technically there are more than 2, but I'm trying to keep it simple)
Dust seals are not designed to hold any real pressure behind them, and because of that, they do not fit all that tight, and because of that, you can run them dry and they will not immediately fail. Oil seals are just the opposite, they are designed to hold a low amount of pressure because they fit really tightly. Because of that, if you run them dry for any real period of time, they burn out. When I say "Fit", what I mean by that is how tight the rubber of the seal is squeezing in against the steel surface that rubber is riding on. A loose fit is for dust, grease, nothing that is designed to hold back any pressure. A tight fit is for water, oil, other fluids, and is designed to hold back a light amount of pressure. (typically less than 25 psi). Because the fit is tight, it must stay lubricated and cooled at all times, or it will prematurely burn out.
For example, if you have ever changed wheel bearings on an older car, or a trailer. Those seals in there are just dust seals, to keep road dirt out. And that's why you can run them without a liquid on top of them without burning up. (but they all burn up in 30 to 40k miles). But if you have ever changed seals on a differential, where there is gear lubricant behind the seals, you can see how they are of a different construction, and fit much tighter.
It's all just rubber on spinning steel.
