Down Limit blocks Bravo III
Speakrdude
Ensign
Am in the disassembly process of 2 Bravo III's clean some corrosion, new steering pins, etc., When I noticed the 2 limit blocks on the trim rams shaft.
The Diagram shows the blocks installed with the large areas opposite each other. The way I found them is with the large areas facing each other.
Which is correct?
achris
More fish than mountain goat
They can be installed either way, depending on how much DOWN limit you require...
