Dp 290 aq271 allingment
Sam Jenkins
Last question I promise.
What is the correct way of allinging the engine to the drive. The mounts on the engine are shot and need replacing. I wanted to check engine allingment after replacing the mounts
Cheers
easiest drive in the world to align.
following the manual.
there are 3 places to measure between the PDS housing and the transom sheild. at 3-oclock, 9-oclock and 12-oclock positions, measure with feeler gauges.
as long as the dimensions are within a 0.060" range (1.5mm) you are good
Sam Jenkins
Wow that sounds nice and straight forward makes a change on a boat.
Are these positions obvious when looking at the back end of the engine.
Thanks again for all of your advice
