DP-A re instalation questions
bransjeep
im near completion of my EFI converison in my invader and since i wasnt the one who remover the drive when the last motor went i want to be sure on how it goes on, im waiting on my last part from fedex tommoro moring and it will be ready to go on, i replaced the ujoints on it, and changed out the gear oil, and the water pipe. the only diagram is the connecting parts page on the volvo penta store and thats not helping me out to much. so any help is appreciated. or a link to a manual or something
captmello
Re: DP-A re instalation questions
I believe its easiest if you install the outdrive without the upper gear box attached. However it can be done all at once.
Install the engine and flywheel cover first.
Install the outdrive second. With the upper off, its much easier to hook up the exhaust bellows and the water intake hose.
Instead of me typing everything that comes to mind, what are you specifically unsure of?
