Thank you Don. The problem is we couldn't easily read it. If I pull a part off maybe there will be a specific part #?It's a DP-S, not sure of the exact model. Should be a tag with that info behind the port trim cylinder.
Thanks Don!Then it's either a DP-S or a DP-S1. They both take the same anodes.
