Hi
I had a missfortunate event where i cracked the case on the lower leg , shop said lower leg is unusable and quoted me for a reman or new. I have heard that i might be able to put on the lower leg also SX-M lower leg .
My old outdrive was DP-SM 1.95 with just 160 hours so if it worth i could reuse the old upper leg .
from what i found i could use SX_M with either 1.43 or 1.51 on SX-M.
So i plan to keep an eye on ebay or various adds to buy something used and i was wondering about compatibility .
I understand that DP is superior to single prop but as i dont use it much single prop might just do what i need .
Also not keen on using the old props .
My engine is VP 5.7GS and the transom is sx-c1.
Many Thanks
Many Thanks
