Dp-sm 1.95 (m22) no drain plug?
codyray
There is no drain plug on my outdrive on the lower unit? Am I missing something ? Do you remove oil from the top?
Ayuh,.... Welcome Aboard,..... Pull the prop, the drain plug is at the 6:eek:'clock position, under the prop,...
codyray
Thank you guys for the help! Will do. I should prob buy a Volvo penta service manual soon.
you can download a manual from volvo penta based on your serial number.
