On my 2006 Cruisers Yachts 340 Express, the port side drive (DP-SM) does not immediately shift into forward when I advanced the lever. In fact, I have to advance the throttle up over 1,000 RPM's (usually 1200-1500) before it will go into gear, and of course this results in a BAM when it catches forward gear.
I do not have this problem going into reverse, only going into forward from neutral.
This started happening about 2 months after I bought the boat last summer. At haul-out in the fall, the marina removed the drive and told me there was water in the gearcase. This might be completely unrelated, but they pressure tested and vacuum tested the drive, there were no leaks anywhere and they said it must have been a bad o-ring on top of the drive, so they said they replaced that o-ring. If there was water in the drive, would that affect shifting from Neutral into Forward only? I didn't think that made any sense.
Launched the boat last weekend, same problem with the shifting into forward.
Does anyone have any ideas for me? I have asked pretty much everyone I know, and posted on a couple forums for help, but nobody has any educated guesses.
Here's the info on the engine/drive......
2006 Volvo 5.7 Gxi 320 hp
DP-SM 1.95 Duo Prop Drive
Mechanical controls/cables.
Thank you in advance for any guidance you can provide. I really appreciate it!
