Fireman78
- May 30, 2018
- 54
Finally getting the boat on the water. Had to install a new driveshaft, set the rolling torque. I have a bad vibration in low rpms, but the vibration is constant through whole range, just in the background. Alignment is “ok” I ran out of adjustment on the mounts. I can push in the bar and spin it with 2 fingers. Just a hair tight.
My other concern is I can spin the props freely either direction in fwd and reverse. I’m sure that is a problem. Maybe I forgot something when I filled it with oil and pulled the props.
there is no vibration when revving the engine in neutral
