My 2006 DP SM (on a chap sig 240) does not have a trim limit switch. So I don't know how far up it can be tilted -
I know there is a limit for full RPM, and I know there is another where you can scoot over sandbars, etc - at 1000RPM,
and yet another point beyond which it should not be operated at all.
So How do I know where these are, and don't say use the trim gage - mine has a faria with only 4 lines not much help at all.
I've heard it is 5 degrees above perpendicular for full speed? anyone confirm?
I've also heard that it is as long as the unit is within the pivot housing guide rails (this is about 1/2 on my gage) - which still leaves maybe a foot under the hull.
What about the point where the engine should not be run ? I've heard 40 degrees off perpendicular.
Also, anyone with a DP tell me if the "real trim range" is pretty small. I start to cavitate or porpoise with not much more than 1/8 trim on the gage.
