DPS-A lower unit drain plug stripped
Senior B
My lower unit drain plug fitting on the drive is stripped out. I have tried a new plug but it doesn't snug up well Im curious if any have removed that piece that the drain plug is in and was it a difficult job?
muc
"Retired" Association of Marine Technicians...
Removing and installing the bearing carrier is a very easy job with the correct tools.
Replacing the bearing carrier is more complex.
Senior B
It is the lower screw that's behind the props. What are the special tools required I wonder.
