drain hole? in 1965 mercruiser i Stern Drive
uplinkguy
I just acquired in a round about way, my father's 1965 Fabuglas 17 ft. boat with Mercruiser inboard moter. His memory isn't what it used to be.<br /><br />Here is one problem: I opened up the grease filler hole to have a lot of water drain out and a cup worth of oil. I refilled the housing with the proper lubricant.<br /><br />Now the question: It appears on the lower unit above and to the left of the grease filler hole, a hole was drilled into the front of the housing facing the bow of the boat on the port side. Is there a legitimate reason for this hole? It does drain water when the stern unit is raised out of the water. The water then beads up and stays in the hole. I touched the water with my finger and more came out. I noticed an hour later that lubricant was dripping out of the hole.<br /><br />The serial number is 1774662B<br /><br />Thanks.<br />Andy
achris
More fish than mountain goat
Re: drain hole? in 1965 mercruiser i Stern Drive
Andy,<br /><br />The hole is there to drain water from the drive when it's out of the water. Lubricant should not be coming out though. This indicates you have a leaking seal in the drive unit somewhere. Probably the shiftshaft seal, top box lower seal or water pump base seal.<br /><br />Chris...........
uplinkguy
thanks, guys!<br /><br />I'll give it a try.<br />Andy
