Drain Plug
Jerryh3
So.... What do you think is the chance of getting this out without snapping off?? Anybody ever remove one from a 10+ year old engine without difficulty. Got it soaking with PB blaster now.
Re: Drain Plug
Ayuh,... Is it steel, or brass,..??
Turn squarely, 'n they usually come right out...
If it breaks, an easy-out will get the remains...
Jerryh3
Re: Drain Plug
I'm pretty sure it's brass. Do you know if that is a 1/8" NPT in the block?
Re: Drain Plug
Ayuh,.... Chevy blocks are 1/4" pipe....
fat fanny
Re: Drain Plug
If it snaps use the smallest easy out 1st and if you get luck and don't horse it it will come out but have a 1/4 pipe tap ready to chase and cut the remaining brass out slowly!! a little at a time. Clean the rust off with a wire brush around the base of the fitting 1st before trying the box wrench (6 point)
Jerryh3
Re: Drain Plug
So, that adapter should be 1/4 NPT(M) to 1/2-13 SAE(F)?
Re: Drain Plug
Ayuh,..... I like the 1/4" brass pipe plugs from the local hardware store....
The 1s that take a 9/16" wrench to remove....
Jerryh3
Re: Drain Plug
Ok. First step is going to try to get that broken nipple out of the adapter. If that doesn't work I'll work on getting the adapter out of the block. Thanks.
fat fanny
Re: Drain Plug
I had the same issue except it was a pipe plug and all I did was drill a hole through it and used an easy out. 1st owner screwed it in too far and never removed it.
Jerryh3
Re: Drain Plug
So I was all ready to do battle with this thing. Had my game face on. Imagined a whole day of drilling and tapping when it snapped off and then.... put a socket on it, barely pulled the wrench, and it started to move. No corrosion at all on the threads in block. Sometimes things work out ok. Hopefully the new one comes tomorrow.
Re: Drain Plug
So I was all ready to do battle with this thing. Had my game face on. Imagined a whole day of drilling and tapping when it snapped off and then.... put a socket on it, barely pulled the wrench, and it started to move. No corrosion at all on the threads in block. Sometimes thing work out ok. Hopefully the new one comes tomorrow.
Ayuh,... Brass rarely corrodes in cast iron,... That's Why it's used....
Ya oughta ditch what ya got, 'n get what I mentioned....
Jerryh3
Re: Drain Plug
If I use a regular brass plug, what should I use on the threads? Just regular Teflon tape?
Re: Drain Plug
Ayuh,.... I use Nothin'....
I boat in sweetwater, I take the brass plugs outa the block, 'n manifolds in the Fall, 'n drop 'em onto the intake manifold...
In the Spring,....
I take 'em off the intake, 'n screw 'em back into where they go,... Just snugged with a 9/16" end wrench,..
I've never had, nor seen any leakage issues, ever, at All....
I here Saltwater Boater's will coat 'em with teflon paste, when pullin' 'em in the Fall for drainin'....
They put 'em back in for winter strorage to preserve the threads in the cast iron,... Less chance of Rust....
Perfect Seal, or Form-a-Gasket, #2 also works, just Fine....
cr2k
Re: Drain Plug
Soft brass will conform to the iron threads ans seal. Teflon tape will lube them making it very easy to over tighten.
