Drain Plugs
joey nathan
Hey All,
I'm looking for a source for replacement drain and fill plugs with washers for my 1975 Evinrude 70HP outboard. I checked the link at the top here and was unable to come up with anything.
Part numbers (from epc.brp.com) are as follows:
0307551 PLUG, Fill & drain upper (1)
0318544 SCREW, Plug gear case lower (1)
0311598 WASHER, Nylon (2)
Thank you in advance...
steelespike
Re: Drain Plugs
I found these under 50-75 3 cyl 79-2003 Evinrude Johnson gearcase parts drain plugs and washers.
F_R
Re: Drain Plugs
You should have been able to order them at the BRP website. Or, any Evinrude dealer. OR, right here at iboats. iboats numbers are as follows:
307551=18-2387
318544=18-2378 (has magnet)
311598=18-4248; 18-4248-9 pkg of 5; 18-42491-9 pkg of 50
