Drain the intake manifold?
Laneman25
Just winterized my 2001 Volvo 5.0 GL 305 Chevy. Did 2 block drains, 2 exhaust manifold drains, and 2 sea water pump hoses.. A video said to drain the intake manifold. Didn't see this in the manual.
Laneman25
I also changed fuel filter, added Sta Bil to tank, fogged engine. No water in filter, so that's good news.
V6 requires the manifold plug to be removed. The V8 doesn't have a manifold drain
Don't forget the annual drive maintenance, and inspection of alignment, u-joints, gimbal, etc.
Lou C
The drain the manifold on the 4.3 V6 applies only to the 96 & up Vortec engines for some reason the intake holds water unlike the older models that drain just like the V8. Make sure to also pull the bottom end of the big hose off of the front circulating pump because that area holds a lot of water…
And poke the holes in the block after you remove the drain plugs.
The other thing you should do is disconnect the raw water intake hose at the impeller housing and hold it down to drain. Then, with the outdrive lowered, hold it up & fill that hose with marine AF until the AF runs out of the outdrive water intakes. This pushes water out of the power steering cooler & hoses that are on the back side of the engine….
Lou C
Yep did my crusty old salt water moored outdrive last week. Looks bad but works great!
