Re: Drain tubes
Its easy. Go to the marine store and buy the brass tube type. You need a wood spade bit that is the same size as the outer diameter of the tube. You drill the hole, then you take the tube and put it through the hole all the way from the outside. On the inside, you measure about 3/16th from the wood, and cut off the excess tube (the tube comes like 3 inches long). There is a tool to flange the lip, but all you need is a hammer and something to use to roll the edge over (the tool is hard to find and expensive, but all it does is create the flange). I use a 3/8th drive socket extention. Before you put the tube in for good, use 3m 5200, and generously apply to the hole and the outside of the tube, and install the tube from the outside of the transom in. Lastly, you will use the hammer and socket extension to roll that 3/16th lip over. You want to alternate across, and figure out a way to keep pressure against the ouside flange. The goal is to have the inside flange you just created hold the tube in tightly, and the 5200 will also keep things put and will seal the water out. Then you just install the drainplug (that you bought seperatly) and you are done.
