2004 Mercruiser 5.0 SN42KBZVV2242000137
Bravo 1 Drive
After reading several different posts and various articicles on winterizing one would get the opinion there are several plugs to remove to properly drain an engine for the winter. One post in particular stresses obtaining and reading a service manual. Best I can tell from the manual, I have an air actuated single point drain system that does not require removing several plugs to properly drain the engine. I have performed the draining method as described in the service manual and the amount of water drained using this method was not near the amount I was expecting.
Is the air actuated single point drain method sufficient for winter?
Bravo 1 Drive
