draining water for the winter
horsefly38425
trying to find the location of the drains on my 4.3 liter. How many are there and the location?
Re: draining water for the winter
Without knowing the Vintage or Make of your engine/ drive,..........
I Know you'll find a Block Drain, down low on each side of the Block,......
There Should be 1 in each exhaust Manifold,........
And,.....
Don't forget to Pull the Big hose from the Engines Waterpump..........
sumcat1
Mine has 5. Lower block just behind front engine mounts on both sides and bottom of both exhaust manifolds and bottom of large hose to the circulating pump. Some have more or less. What year,what 4.3 and what cooling system? Mercruiser says to put the plugs back in to keep rust off the threads in the block. Watch out for O-rings on the plugs. Easy to lose.
Laddies
Banned
If its a early 4.3 with a oil cooler under the port manifold remove the hose from one end of the cooler
