Drama-free towing.
Frank Acampora
A good news story:
Just got home from a 125 mile tow. When we picked up the boat it had both tires flat and no hub caps. We filled the tires and towed the boat about a couple of hundred feet just to see how bad the bearings were. It was a foregone conclusion: replace them, we won't get 2 miles. So, off to Wal Mart for two sets of bearings and a tube of grease.
We replaced the bearings right there on the tailgate of my truck.
We were prepared: We had steel and clamps to reinforce the axle--not needed, a small portable compressor to inflate the tires and spare--well worth the money we paid for it, various hand tools, and a set of magnetic lights--again, very good to have since the trailerd did not have any lights or mounts (and we were not told) A bottle jack was really handy.
The wheels did look heavily rusted but were sound and usable. At first, I though the trailer was way too small for the boat but the registration showed it at 1500 pound capacity and while this rig was probably just touching that limit, it certainly was not overloaded.
So, after about an hours's work, off we went from Rehoboth, De. to West Chester, Pa. At highway speeds, wheel hubs ran cool, lights worked, and trailer tracked well. It was an uneventful trip with no drama because we made the correct decisions before towing. The thirty dollars spent on bearings probably saved us well over a couple of hundred if we had broken down during the trip.
Outsider
Re: Drama-free towing.
And you weren't concerned by those hubs? Not even a little bit? Big ones, you got big ones ... :facepalm:
Frank Acampora
Actually, I anticipated the bearing races would be cold welded into the hubs and difficult to remove. In fact, I did discuss going to West Marine and buying complete hub assemblies.
However, the races pressed out without much fuss (except for breaking one pin punch on the first hammer hit) and the new races pressed in quite nicely- just the right interference. The inside of the hubs were in very good condition--especially considering that the bearing rollers were just dropping out of the cages and were spalled almost beyond recognition. Seal surfaces were similarly in good serviceable condition.
So, No, after inspection I was not concerned about the hubs. And yeah-- I do have big ones. Oh! too much sharing! LOL
BTW: That is not me in the photo. It is the guy who set up our getting this boat and trailer. He is actually twice my size.
marcoalza
Nice one Frank.
Good to read your experience.
Well prepared will conquer all my friend.
GA_Boater
Well it's just no fun when you come ready to do battle. Makes the trip a :sleeping:er. I would have been more worried about the wheels than the hubs. Glad you had a no drama trip!
bruceb58
Is the guy really using a screwdriver to knock out the races?
Outsider
I was referring more to the lug holes. They look pretty scary to me ... :facepalm:
Frank Acampora
No, he was not knocking out the races--I would not let him do that; he tends to be a bit ham-handed. He was scraping out all the old goo. If you look closely at the tailgate photo, you will see a punch set. As far as the lugs, the area around them was rusted but again, only surface rust: The holes and lugs were sound.
bruceb58
Ok yeah..see the punch set. I was worried that if he was using a screwdriver, what else did he do wrong!
Frank Acampora
And, if you have been following that "other " tire thread, I towed with the tires at max air pressure. 5.30X12, 1020 lbs load limit, 80 PSI max. I was a bit surprised at the 80 PSI rating. I expected it to be 40 or 50.
F14CRAZY
Ensign
Much better than my buddy who lost a wheel/tire and screwed up an axle due to bad bearings. Thank goodness it was a double axle trailer
