Dressing Aluminum Weld
TEutis
I had a previous post where I had some damage to my outdrive - the cavitation plate more specifically. I took it to the shop and had it welded but when I got it back the welds have not been grinded down. Is this for a reason or can I grind them down with a flapper type grinding wheel so it looks a little nicer. Thanks for any advice.
Re: Dressing Aluminum Weld
Ayuh,... Sure, go ahead... No reason not too...
coheej
If the welder knew how to weld aluminum you can.
I would start with a carbibe burr made for aluminum first, then finish it with a sanding roll.
TEutis
Thanks for the advice, appreciate it!
