Drilling larger holes
alldodge
Have always used hole saws to drill holes above 3/4 inch. Still want to redesign my helm gauges but currently installing another gauge (2 1/8). For temporary purposes this season, I'm removing the speed-o (4.5 in) and installing a plate and new gauge in it.
Cutting thru aluminum so are there better options?
MTboatguy
Unfortunately that Harbor Freight circle cutter is not very good, I have one and it is hard to keep tightened down and gets wobbly. I have a large selection of Milwaukee hole saws, but for the size you need, I would use my Rotozip with the circle attachment. If you have a rental company around they may have something you could rent to do the job.
alldodge
I have a rotozip and have not tried to do round holes yet
harringtondav
I have a circle cutter like GA mentioned. It works well with a little practice. Another poster was wondering about cutting a large hole in his fuel tank. I suggested this as an alternative. HVAC guys use these to cut holes in duct work for star collars.
Click image for larger version  Name:	cutter.JPG Views:	3 Size:	7.7 KB ID:	10844559
blamtro
I did this a few years ago and bought hole saws of various sizes up to 6” but if i remember correctly the most common size was 3-4”? Holesaws made it easy once I had the right size.
