Moody Blue
- May 24, 2004
- 3,136
Needed to remove the windshield wiper linkages from the van to get access to the upper strut mounts tucked back under the windshield cowling. Broke the head off a bolt fastened into a tapped hole in a casting. No problem I figure, I'll just drill it out and re-tap the hole. Done this numerous times before.
Well after an hour and countless drill bits I had drilled less than 1/4" into the broken bolt. I tried HSS, titanium coated and cobalt drill bits with no success. Finally I got out the carbide burr and die grinder and ground it out.
I don't know what material or hardness that bolt was but it was like nothing I've encountered before. It was only an 8mm (5/16") bolt, not real big. I've got another to remove and fear the same outcome. Any suggestions ?
