Re: Drilling through my hull, what to use?
A through the hull outlet for a bilge pump line is normally in a 1" opening. The tube is then connected to the pump.
Drill a small hole and work your way up in size and drill bits. A nice sharp set of metal bits will work fine. If the largest you have is 1/2 you can carefully widen the hole with it then use a file to finish the hole.
You should not get any cracking with a sharp bit if you start small.
Use 3m5200 or 3m4200 to act as a sealer for the fitting......... DO NOT use silicone (it will fail).
Be certain to drill the outlet high up on the boat. You do not want it to act as an inlet when you are fully loaded
