I am gearing up to do a transom job (gimbel, u-joints, etc.) and am confused as to when I would need to have the engine alignment tool. I would assume that I need it anytime I shift the engine or bell housing mounted to the boat transom, right?<br /><br />I guess you could also use it to check the gimbel alignment after you slide hammer it out. BTW, what is used to press the gimbel back into place?
