Drive Fluid Compatibility
Knot Waiting
The brand of oil I have been running in by Alpha 1 is no longer available in my area so I was going to switch to Mercury High Performance sterndrive fluid. However, Mercury states on the bottle not to mix theirs with any other brand of fluid. My question is: The residual amount of fluid left in the gear housing after an impeller change is not significant enough to apply to this condition is it? Just wnated to error on the side of caution. Thanks
Don S
Re: Drive Fluid Compatibility
Drain the oil out, there is quite a bit of gear lube in the lower unit.
Ayuh,... If you drain the Outdrive, then drop the lower to change the impeller...
The residual oil will be immeasurable, 'n inconsequential...
joncrisler
If you completely drain (via drain plug on bottom) the old drive oil, whatever is left would not cause any harm with the new oil. That said, I doubt there is any compatibility issue- its probably just the concern that the new oil would be deluted by the old oil.
