Re: drive lift
I have a 1985 ciera with a volvo 280 drive. The drive lift light will come on whenever the drive is lifted even a little. That drive was meant to be run in the full down position. The only reason it has lift is to trailer it. There was no trim on it. I have been told that if you lift it to far while running it that it will hit the flywheel and cause big problems. I hope this helps.
