Re: Drive Loss
Thanks Haut,
Pulled the dip stick and there was metal shavings (yikes!) and then I popped the top cover and saw that the gears had had a fight (yikes again!!). If the outdrive overheated I was unaware of it. The gear case oil seemed a little low, but it has not been leaking.
So, the question now is what to do next. Is it common that those gears go after a while (say 15 years)? When they do go, do they cause collateral damage? Is this a job that a modest do-it-your-selfer should tackle? What is a typical service fee for having the upper case repaired. Should I get a rebuilt one or new. Sorry about all of the questions, but I think at this point if I don't hit the post button, I will have some more. Jeez.
Thanks again.
