Drive making roaring noise( beating noise)
Waltsfastz
Just bought this boat and took it out today. 98 ebbtide. Works good but has a growling like a searing noise coming from the drive. It does it in gear or in neutral. I have never been in o w of these and only done a couple water pumps on outboards.
question is what bearing are prone to failure? Start at the input shaft ( horizontal) or drop the lower unit and work up? Thanks for any help and suggestions
Ayuh,...... Welcome Aboard,...... Is it full of oil,..??..??
Drain the oil, 'n look for metal,......
Grub54891
What Hondo said. If you can post a pic of the drained oil would be good also.
harringtondav
While you are at it pull the the top cap on the outdrive and take a pic of the innards after you drain the oil and share the pic.
3/8" 12 point socket.
Waltsfastz
Couldn’t sleep. Found the culprit. Gimbal bearing( I think that’s what it’s called) nasty and rough. Oil looked ok. Had some derbisnon the magnet that doesn’t look pleasant but nothing I’d think is excessive. Turning the shaft on the outdrive it is nice and smooth.
I understand these bearings can come out with a slide hammer. I think I have an axle pulled attachment that will work. However the water in the bottom of the bellows bothers me. The universals didn’t look as if they have been wet
so what to do? Obviously replace the bearing but is a little water normal or should it be completely dry? Also is the o rings on the shaft to seal the bellows from the engine side? Or to alight the shaft with the bearing?
get a complete bellows kit along with a gimbal bearing and the alignment tool and bellows tools
Waltsfastz
Sounds like a winner. Any links or pics of the special tools? I have seen the tool to take the horlizinal pins out. What needs to be aligned?
Grub54891
An alignment bar us needed to check it every time you remove the drive for service. You put it through the gimble into the coupler to see if everything it true. Read the stickys at the top of this forum and you will find lots of good info.
tank1949
If ya replace gimbal, examine billows. If older than 5 years, I'd replace it too. Also replace inner transom seal (behind gimbal bearing before shaft goes into coupler. Water got into it from somewhere?
Waltsfastz
I’d say it has sone age on it. It is pretty stiff. I’ve watched some videos on how to remove the bell housing. Any tips? Also is the adhesive necessary?
Bt Doctur
If you can tell us exactly what you have, what motor and what drive I`m sure we can find you a manual
nola mike
Also get the gimbal install tool. Sold as a package with the alignment tool on eBay.
Waltsfastz
So I have made an alignment shaft. Does anyone have dimensions for The bearing instal tool to use with it? Of some dimensions of the bearing? Mainly the old and how much the inner race sticks out past the outter race?
nola mike
I have one waiting to go in, I can measure when I'm back on Thursday or Friday if you remind me...
