smiles16
- Jul 25, 2016
- 186
So about a month ago I posted a couple topics pertaining to my boat restoration, particularly the engine swap. All is now good in that area, with a nice low hour, late 80's mercruiser 120 in place. Had to have the bearings replaced and revealed on the alpha 1 gen 1, so it's like new.
First problem, engine ran fine with a line running directly from the pump to a portable gas can. After installing the new fuel lines and water separator, I can't seem to get fuel to the pump. I found a trickle of gas in the filter. Do I just need to keep pouring fuel in the carb and run it long enough for it to catch prime?
Second problem (maybe). The drive makes a light clicking sound when trimmed up and running on muffs in neutral. Is this normal? If not, thoughts? I know my gimbal and joints are good. Shifts in and out of gear just fine.
Third question, do I absolutely need trim senders? The wires are rotted out. Plan on replacing these when I service the bellows in the spring. Just want to make sure I won't blow anything up during the test runs.
You guys are awesome, any advice would be very helpful.
