Re: Drive oil leak at prop
The shop has mine apart now. They say that the thrust hub was seized and scored the shaft a bit. They think they can re set the seals slightly deeper on the shaft to avoid the damaged area which would avoid replacing the shaft etc. Hope it works, much cheaper fix. Then decide to sell or upgrade the boat. The mechanic indicated that the repair could last quite some time?? I hope that's the case.
Any comments?
Thanks
