I have a 97 Glastron Mercruiser 3.0 w/alpha drive. Have been boating serveral times with no problems. Came home from work the other night and the Drive oil reservoir had emtied itself out the sterndrive all over my driveway. I checked the sterndrive first and changed the oil, clean and fine, let set over night, no additional drainage. While checking over Engine compartment(I'm big on maintenance), found the drive reservoir empty. No leakage inside boat anywhere. Looks like it is coming out the stern drive either from the Weep holes on the sides of the lower unit, or the fitting just in front of the shift actuator rod on the lower unit, where the oil line comes down. I have checked the fitting - not cracked, o-ring is not compromised. What could cause this "drain" all of a sudden?<br />I am new to boating, but not mechanics - my apologies on incorrect referencing to part names.<br /><br />thanks,<br />KCBoater
