Drive-On vs. Non Drive-on
DoctorCAD
I need to convert my non drive-on trailer to a drive-on type. Can it be done easily?<br /><br />I currently have 3 keel rollers and 2 stablizing type bunks. What do I need to add?<br /><br />Boat is a 15' Starcraft aluminum Kingfisher, trailer is a factory matched Snowco.
Re: Drive-On vs. Non Drive-on
?????????????????<br />That's Technique, Not Hardware.......
JB
Got side guides and side bunks? You will need them.
DoctorCAD
I dont think I could drive-on with the way the trailer is set up now, even pulling the boat on with the bow line is quite difficult.<br /><br />JB - Can I just add just add side guides and side bunks? I have guide-on posts (mostly for mounting the lights and backing up the trailer when empty) but I doubt that they would hold up to bouncing off them.<br /><br />I watch people at the ramps just kind of lining up and powering on, the boat seems to fall right onto the trailer. Is that what the side guides are for?
You've Got It,... Doc...<br />Try backing in, a little less, or a little more....<br />If you "Sink" the trailer, just pull the boat up to the winch,+ pull out... Your Side-Guides Should center the boat For you.....<br /><br />BTW, One of My Personal Pet Pieves.....<br />Is the Guys who Don't back in far enough,+ Then Power Onto the wagon......<br />Doing this Digs Scour Holes in the launch.....<br />Then Guys like Me, Back in Far Enough,+ the trailer Falls into a Big Hole.......<br />It's sometimes Tough to Haul-Out of these Big Holes, with the weight of the boat on the trailer......
