I have a 1973 pre alpha outdrive. Serial #3587533. I took the whole thing apart to fix a bent prop shaft. After putting everything together I noticed the drive shaft (not prop shaft) has about 1/16 -1/8" play (up/down). It will pull up that much when I pull on it. Is this normal? It seems that it would wear out the water pump with this much play. I have a Clymer's manual and it only give me info on side play, not up/down play on the drive shaft. Thanks.
