Due to a broken skeg (which occurred before I bought this outboard) I am thinking of replacing the Gearcase Housing Assembly. There seems to be slight milkish Gear Oil and some water after running with new gear oil in a tank for a just few minutes (to check the Thermostat/PeeStream). It is possible I had a bad gasket on the upper Drain Screw, or I suspected bad seals around the Prop Shaft. So using my redneck Pressure Test setup (small air compressor and tube/fitting robbed from a gear oil pump) I pressurized in a bucket of water and see no leaks whatsoever around Prop Shaft or anywhere else. However I did notice that the drive shaft pops up about 1/2 inch when I apply pressure (about 15psi), then when I release pressure the drive shaft returns unassisted to Down position.
Is this normal for the drive shaft, or does this up/down Driveshaft movement indicate something is wrong (that could the root cause for water in the Gear Oil)?
Also, exploded diagrams I see call for Gearcase Housing Assembly 397701. Will a Gearcase Housing 336298 work instead? Seller indicates Bearing 386071 will need replaced. Is there any reason I can't use my existing Bearing 386071 (for example, it could be difficult to non-destructively remove the Bearing)?
thanks for input...
thanks for input...
