Drive shaft question, getting ready to re-assemble my outdrive after a water pump replacement and a shift shaft seal. I know I was able to turn the drive shaft when I did the water pump as I had to turn it to get the impeller into the housing. When I replace the seal on the shift shaft I was very careful not to turn the prop shaft while the shift shaft was out, and I put the shift shaft back into the same position it was before I removed it.. After replacing the shift shaft seal and with the water pump housing tightened down, I cant turn the drive shaft by hand. Is this normal with a new water pump?
1995 Merc Alpha 1 Gen 2
S/N 0f507678
S/N 0f507678
