Re: Drive shaft removal from power head on 2hp Evinrude
get a weight lifting weight ,bigger the better,slide it on the shaft,then take a couple pair of vice grip pliers,tighten to the shaft and use the weight against the pliers as a slide hammer,I have heard of guys welding a washer in lieu of the pliers,you do with what u have
