Drive shaft seals lower unit 89 25hp johnson
chipper31
After you pull the driveshaft out of the lower unit there is 2 seals there. Do I need to know anything special about pulling these and replacing them? Any special tool I need or can I coax them out normally? I am the new guy on this block,,,cool place. Thanks
jasper60103
Re: Drive shaft seals lower unit 89 25hp johnson
A seal puller will make the job easier. Your local auto parts store should have it. I paid $11 and the seals came out in a couple minutes. Work it out slowly, nibbling around the inside ring.
chipper31
Thanks for that,,makes me happy. Who needs to buy another tool,,,once again,,thank you very much.
R.Johnson
That tool will gouge a seal housing as good as any screw driver. The proper tool can make a job 100's of dollars cheaper. If the seal is corroded in at all, that puller could make you very sorry. I wonder why they call it a puller?
chipper31
Good point Mr. Johnson,,,I will be extra careful. I have pulled hundreds of seals before, but never on a boat motor. Believe me I know what boat parts cost. Once again guys thanks for the hot tips. Will let you know how it goes,,should happen tonight when I get the rest of my parts in. Chip
jasper60103
With proper use, it will do just fine. Did it myself (as a newbie). I would not recommend it otherwise. Sheesh!
chipper31
Man that seal was in there!! I ended up taking a long nose set of tin snips and cutting the middle part outwards 5 spots. This ruined the integrity of the seal and it popped right out. Everything good now,,new seal in,,water pump kit in and I am ready for the rest of my parts to go in.
jasper60103
yea, that's basically how it comes out in the end. After you nibble at it for a while, you can grab it with long nose pliers and persuade it out. Glad things worked out.
