Drive Shower
Riv
Going to put a drive shower on my Bravo1. Want to get a unit that is quality and cools correctly. Can anybody give testimonial to any product they have used?
lmannyr
Master Chief Petty Officer
Re: Drive Shower
There is a drive shower on ebay now. Do a search. Check it out. It's a very simple piece of hardware I think a handy guy could make for a couple bucks and some spare time.
Good luck.
wvit1001
Re: Drive Shower
Drive Showers are just another example of boating equipment whose only real purpose is to seperate fools from their money.
bomar76
Re: Drive Shower
Drive showers are proven to lower drive temp.
There are many good unis out there, I personally like the Simrek.
Imco make a great unit also.
wvit1001
Re: Drive Shower
OK, so it lowers the temperatures. But does that make any real difference? There are plenty of outdrives out there that run for years with no problems. Lack of maintenance is what hurts drives.
lmannyr
Re: Drive Shower
I would think with proper maintenance AND the shower the owner can extend the drive's longevity. The shower wont hurt for sure.
wvit1001
Re: Drive Shower
Unless your running really hard for extended lengths of time then you should save your money for beer and gas.
Re: Drive Shower
Ayuh,....
I've looked at a few,..... An had a few Ideas.....
I think that Anytime you can cool the oil,... Your buying longevity,... Less rebuilds,+ Longer times between Reseals.....
Running out into the lake for a few hours on plane, I'm sure heats the oil, well over 200?........
If I can keep it down to 180?,... Or Less.....
I'm gonna Do It,.....
Matter of fact,... I've got abunch of Pieces,..... I'm just lackin' the Time.......
Coors
Re: Drive Shower
It can be kinda be like why your automatic transmission has a cooler.
eastern27
Re: Drive Shower
I'm new here, but run a Bravo 2. Never heard of drive shower, or seen on for that matter. Is it a warm water thing?
rodbolt
Re: Drive Shower
no way in L that drive will see 200 degrees.
I have 28-36 ft boats with twin bravo 1,2 and 3 as well as volvo DP drives do do regular trips to the gulf stream that dont use drive showers and do it for years on end with no issues.
automatic trannys compress fluid so they need a cooler, you dont see coolers on manual shift plus a drive will cool by contact with the water.
Aluminium actually transfers heat fairly well.
TAV MAN
Re: Drive Shower
Can you put a drive shower on any drives
lmannyr
Re: Drive Shower
Tav,
Yes you can. I'm not an drive expert but, it just a matter of bending some stainless tubbing correctly. Then mounting it. There are so many ways this can be done, one can be very creative.
rodbolt,
No one is saying this is ABSOLUTELY necessary. In fact, I rarely ever see these showers on drives. I bet it will only help longevity though.
Have a nice DAY!!!
wvit1001
Re: Drive Shower
Hey, I've got some stainless steel glovebox knobs that I guarentee will give you 5 more hp and 10 extra mph. Only $25. Anybody want one?
45Auto
Re: Drive Shower
Didn't you know that was why you HAVE to use automatic transmission fluid instead of oil in automatic transmissions? It's the only compressible fluid known to man!! :) :)
45Auto
Re: Drive Shower
All high performance automotive manual transmissions required to operate under extreme conditions (NASCAR, endurance racing, etc) of RPM and power output use transmission oil coolers (they also use differential coolers which I think would be more analogous to a drive cooler). Same conditions apply to the hot-rod boat crowd. The Cigarettes, Fountains, Formulas, etc with twin 1000 HP engines turning 6500 RPM running from Miami to the Bahamas at 100 MPH probably definitely benefit from a drive shower. They supposedly make a huge difference on the life of the upper bearing. The normal IBOAT reader who runs at 40 or 50 MPH for a half hour at a time max before coming off plane and cooling the upper drive probably won't see any difference.
One of the signs of your outdrive getting hot is white calcium deposits on the upper from it getting so hot it boils the water when you come off plane and it drops back in. That says to me that it has to be over 212 degrees. Everything I've read about drive showers says they keep the upper cool enough to eliminate these calcium deposits which means the upper is below 212 degrees.
Only disadvantage to them is that some of them require drilling holes in your cavitation plate which voids your corrosion warranty. I think the newer Simreks attach to the ram bolts and don't require drilling holes.
I figure they're cheap and don't hurt anything. They actually may help. I'm kind of like Bond-O, I intend to put one on my B3 this summer when I get around to it but it's not the highest priority on my list!
Don S
Re: Drive Shower
There is a very simple test to see if you need a drive shower or not.
When you change your gear lube (100 hr, or yearly whichever comes first) if the oil smells like gear lube and looks a little darker than normal, then all is fine.
However, if the gear lube is black and smells burned, then you may benifit from using a drive shower.
